IR Leak Detection
The ThermaCAM P25F IR cameras from is designed for high-temperature industrial furnace applications. It can help ensure safe operation by monitoring all types of furnaces, heaters and boilers, particularly in the petrochemical and utility industries - to ensure safe and efficient operation. The camera is ready to be used in less than one minute, which is a beneficial feature in high-heat enviro...
The ThermaCAM P25F IR cameras from is designed for high-temperature industrial furnace applications. It can help ensure safe operation by monitoring all types of furnaces, heaters and boilers, particularly in the petrochemical and utility industries – to ensure safe and efficient operation. The camera is ready to be used in less than one minute, which is a beneficial feature in high-heat environments. The camera uses burst recording to record and archive a series of images, and comes with a detechable heat shield.
Flir Systems www.flirthermography.com Write 300 on PE card
