Intensifier pump
The iP55-280DS diesel-powered waterjet intensifier pump is suitable for use in remote and mobile locations where electricity is scarce.
The iP55-280DS diesel-powered waterjet intensifier pump is suitable for use in remote and mobile locations where electricity is scarce. The 280-horsepower turbo diesel engine meets domestic and international Tier 3 emissions standards. The pump is capable of producing flow rates of up to 4.1 gallons per minute of 55,000-psi ultra-high pressure water for waterjet cutting, surface preparation, and cleaning applications. The pump also is equipped with a pressure-compensated hydraulic system to drive dual plunger-style intensifiers. The use of hydraulic fluid power provides smooth flowing UHP water.
Jet Edge www.jetedge.com
