Insulated cables for supplying power to frequency converters
Helukabel's Topflex-EMV-UV-3 Plus 2XSLCYK-J and the Topflex-EMV-UV-2XSLCYK-J are suited for supplying power to frequency converters and are both designed for medium mechanical loads in fixed and occasional flexing installations. Uses include automotive, food and packaging industries, in environment technology, handling devices, pumps, fans, conveyor belts, air conditioning devices, and in explosive environments.
Helukabel’s Topflex-EMV-UV-3 Plus 2XSLCYK-J and the Topflex-EMV-UV-2XSLCYK-J are suited for supplying power to frequency converters while ensuring electromagnetic compatibility (EMC) in systems, buildings and facilities from devices and operating equipment, which can emanate electromagnetic interference (EMI) and cause impermissible malfunctions. They are designed for medium mechanical loads in both fixed and occasional flexing installations in wet rooms or outdoors. They are suitable for use in the automotive, food and packaging industries, in environment technology, washing machines, handling devices, pumps, fans, conveyor belts and air conditioning devices. They can also be used in explosive environments. They are also RoHS-compliant.
Both cables are jacketed with a PVC compound, double shielded, and use XLPE insulation on the inner conductors, which makes them ideal for applications that experience high voltage spikes and have long cable runs due to their low capacitance. Both cables are also UV resistant, self-extinguishing, and flame retardant. The low transfer impedance results in good electromagnetic compatibility. The materials used are free of silicone, cadmium and substances harmful to the wetting properties of lacquers.
Helukabel
www.helukabel.com
– Edited by CFE Media. See more Control Engineering energy and power products.
