Industrial Modbus gateway expands network connectivity
The Matrikon Industrial UA Modbus Gateway is a native Modbus communicator that can connect to any device that uses the Modbus protocol over serial or Ethernet connections on one side and makes it available to OPC UA clients on the other via OPC UA over Ethernet.
By MatrikonOPC October 23, 2014
The Matrikon Industrial UA Modbus Gateway is housed in a small form factor gateway designed to deliver secure and powerful connectivity to access data from RTU’s, PLCs or any other devices that use the Modbus data protocol. The UA Modbus Gateway is a native Modbus communicator and can connect to any device that uses the Modbus protocol over serial or Ethernet connections on one side and makes it available to OPC UA clients on the other via OPC UA over Ethernet. The UA Modbus Gateway allows data sharing via UA as natural next step up from using Modbus. The gateway is designed for challenging situations like limited power availability in remote conditions, remote or unmanned stations that need data collection, and operations in extreme temperatures and/or dusty environments.
MatrikonOPC
www.matrikonopc.com
– Edited by CFE Media. See more Control Engineering networking products.
