Industrial fan
The Powerfoil X industrial fan uses its NitroSeal Drive to reduce gearbox maintenance and run the fan at a cooler temperature. The hermetically-sealed drive is nitrogen-filled to ensure zero moisture and contamination. The hollow output shaft allows for the integration of electronic devices such as a light, camera or VESDA smoke detection.
The Powerfoil X industrial fan uses its NitroSeal Drive to reduce gearbox maintenance and run the fan at a cooler temperature. The hermetically-sealed drive is nitrogen-filled to ensure zero moisture and contamination. The hollow output shaft allows for the integration of electronic devices such as a light, camera or VESDA smoke detection. The fan’s onboard electronics eliminates electromagnetic and radio frequency interference. The wall-mounted, low-voltage Cat5 keypad can control several fans up to 1,000 feet away.
Big Ass Fans www.bigassfans.com
- Events & Awards
- Magazine Archives
- Oil & Gas Engineering
- Supplements
- Salary Survey
- Blogs
- Digital Reports
- Survey Prize Winners
- CFE Edu
