Industrial chassis for factory, building applications
Advantech's ACP-2020 is a 2U rackmount industrial chassis that enables self-diagnostics and remote monitoring of power, temperature, and fan speed status.
By Advantech August 12, 2016
Advantech’s ACP-2020 is a 2U rackmount industrial chassis designed for factory automation or equipment building applications with space limitations. The ACP-2020 is equipped with an intelligent system module that enables self-diagnostics and remote monitoring of power, temperature, and fan speed status. The ACP-2020 supports ATX/uATX form factor motherboards such as Advantech’s AIMB-7/5 series and ASMB-7/5 series. The ACP-2020 supports two internal 2.5-in. hard drive spaces, two external 2.5-in. hard drive spaces, and an optional dual SATA hot-swap module which can be used externally. Power comes from a 350W single power supply or 500W redundant power supply.
The shallow depth chassis leaves more space internally with careful cable arrangements for better air flow. The 500W redundant power supply allows usage of high performance CPUs and add-on cards such as graphics or frame grabber cards. An intelligent embedded system module provides end users with remote monitoring of system health which can reduce the frequency of costly on-site maintenance.
Advantech
Advantech Co-Creating the Future of the IoT World
– Edited by CFE Media. See more Control Engineering industrial PC products.
