In-Line Cat6 Lightning and Surge Protectors
L-com, Inc., has expanded their ELP series protector line with two new Cat6 lightning and surge protectors. These products protect valuable equipment from static discharge, lightning and faulty wiring.
The Cat6 protectors are easily installed, built for durability and feature rugged aluminum construction.
Designed for 10/100/1000 Base-T Gigabit Ethernet networks, it features RJ45 jacks and is easily connected in-line with existing data cables and is compatible with 802.3af/at Power-over-Ethernet (PoE) devices and support PoE mode A and B for power.
It is mountable to standard DIN 3 rails with 3, 5 and 10 position busbars also available.
For more information about this release, please contact: pmcneil@l-com.com
