High voltage and current digital panel meter
Precision Digital's PD6400 High Voltage and Current Meter is designed to provide reliable measurement of high voltage, current, and apparent power and it features field-selectable current and voltage inputs accept up to 300 V and 5 amp, ac or dc.
Precision Digital’s PD6400 High Voltage and Current Meter is designed to provide reliable measurement of high voltage, current, and apparent power. Independent, field-selectable current and voltage inputs accept up to 300 V and 5 amp, ac or dc. The user-configurable, dual-line display features easy-to-read LED digits and warning lights with adjustable brightness. The Modbus capability (Slave) allows seamless integration into existing networks. The PD6400 is NEMA4X/IP65 rated for use in a panel or in the field under harsh environmental conditions; it also carries CE and UL listings. The meter can also accept current transformer inputs for even higher current measurements. The displayed voltage, current, or apparent power level can be clearly labeled with a custom tag and unit. The voltage and current can also be scaled to represent different engineering units. Options for the PD6400 meter include up to four relays, a 4-20 mA analog output, and a 24 VDC power supply.
Precision Digital Corp.
Precision Digital – Digital Panel Meters and Explosion-Proof Instrumentation
– Edited by CFE Media. See more Control Engineering energy and power products.
