High-temp grease has drop point of 630 deg F
Paragon 3000 high-temperature, extreme pressure grease has a dropping point of 630 deg F, plus outstanding extreme pressure chemistry with 100 lb Timken OK load.
Paragon 3000 high-temperature, extreme pressure grease has a dropping point of 630 deg F, plus outstanding extreme pressure chemistry with 100 lb Timken OK load. The nonclay base grease is water-resistant, highly impact resistant, and offers excellent mechanical stability and long service life.
Texas Refinery Corp., Lubricants Div.; www.texasrefinery.com
TO VOTE, WRITE 48 ON BALLOT
For more information, circle 49 on card
