Heating tapes
The HTWAT series of silicone rubber heating tapes feature an adjustable thermostat control up to 218 C and are designed for process temperature control, freeze protection and supplemental heat.
The HTWAT series of silicone rubber heating tapes feature an adjustable thermostat control up to 218 C and are designed for process temperature control, freeze protection and supplemental heat. The tapes are moisture and chemical resistant, suitable for electrically conductive surfaces and heat up at a very quick rate. Recommended applications include valves, pipelines, bearings, filter housings, actuators and more. The tape’s designed uses include manufacturing, construction, petroleum and public works industries. This product is CE compliant.
Omega Engineering Inc.
- Events & Awards
- Magazine Archives
- Oil & Gas Engineering
- Supplements
- Salary Survey
- Blogs
- Digital Reports
- Survey Prize Winners
- CFE Edu
