Generator-paralleling switchgear system
Emerson Network Power has redesigned its ASCO 4000 Series Generator Paralleling Switchgear with custom capabilities.
Emerson Network Power has redesigned its ASCO 4000 Series Generator Paralleling Switchgear that offers custom capabilities in a mid-range system. The redesign features monitoring and control that is independent of the operator touch screen, and generator control that is independent from the master controller. The system provides diagnostics for monitoring of critical system components such as digital power meters, digital genset controllers, circuit breakers, and more. Displays include genset status/control and trending, historical alarms, power transfer switch status, and a range of metering data. When adding and shedding loads, it accounts for measured values of building loads on the main bus, rather than considering online generator capacity.
www.EmersonNetworkPower.com
