General and Maintenance Software
Software gets to root cause of problems Proact V2.0 root cause facilitation software manages a knowledge database of solved events and allows users to benefit from the results.
11/01/2000
Proact V2.0 root cause facilitation software manages a knowledge database of solved events and allows users to benefit from the results. An enterprise version permits the sharing of logic used to solve failures within a corporation and also features an online presentation mode, file-linking to match pictures with hypotheses, and easy-to-build logic tree. System uses facts to draw accurate root causes and provides full, consistent documentation. Reliability Center, Inc.; www.reliability.com
TO VOTE, WRITE 3 ON BALLOT
For more information, circle 3 on card
Training tool helps with vibration analysis
Analysis Assistant interactive training and performance support product provides both new and experienced vibration analysts with a comprehensive resource guide to help them perform analytical processes. Software lets users access information by problem or symptom. Topics covered include unbalance, misalignment, bearings, belts, bent shafts, and more. Universal Technologies, Inc.; www.unitechinc.com
TO VOTE, WRITE 6 ON BALLOT
For more information, circle 6 on card
Web-based CMMS needs no terminal server or network
Web Work CMMS is 100% web based. Modules include work requests, work orders, inventory, equipment, labor, purchasing, stock reports, and more. System uses standard html, SQL, and scripts to accomplish maintenance tasks without the need for costly hardware and software normally associated with traditional CMMSs. Thin-client configuration offers more functionality than most traditional packages. Tero Consulting Ltd.; www.teroconsulting.com
TO VOTE, WRITE 73 ON BALLOT
For more information, circle 73 on card
Software tool analyzes productivity
Factory Pulse network enterprise edition is a portable, integrated hardware and software system designed to analyze productivity through cycle time and downtime analysis. An "industrial engineer in a box," the system performs process optimization and workflow analysis from multiple points in the plant. Package installs quickly, is scalable, and includes visual trending software to view any combination of machines at one time. FactoryWare, Inc.; www.factoryware.com
TO VOTE, WRITE 100 ON BALLOT
For more information, circle 100 on card
Enterprise application streamlines MRO supply chain
Maximo Extended Enterprise includes maintenance and repair optimized e-procurement features to streamline the MRO supply chain. Application saves administration and transaction costs, and improves sourcing that can produce up to 10% savings on purchases. System automates procurement from the plant floor to the supplier's door. PSDI; www.psdi.com
TO VOTE, WRITE 102 ON BALLOT
For more information, circle 102 on card
Inventory management system features remote display
SiloPatrol inventory management system features a remote display unit that lets the user view latest measurements from any of a number of points. The system includes smart sensor technology with a multifunctional user interface to provide reliable measurement of material in tanks, bins, and silos up to 150 ft. SiloTrack software permits monitoring of up to 128 vessels from a single PC. Monitor Technologies LLC; www.monitortech.com
TO VOTE, WRITE 108 ON BALLOT
For more information, circle 108 on card
EAM solution cuts cost of ownership
MainsaverNOW hosted total service provider solution reduces up-front purchases and implementation costs associated with traditional client/server software. The system provides all the features of the Mainsaver EAM/CMMS software suite for a fraction of traditional on-site application costs. Software system helps reduce downtime, control expenses, optimize inventory, improve purchasing efficiency, and more. Cayenta, Inc.; www.cayenta.com
TO VOTE, WRITE 115 ON BALLOT
For more information, circle 115 on card
Hosted EAM lets users access software over web
MPXconnect is a comprehensive enterprise asset management service offered as a hosted application. ASP deployment model lets users access the software over the internet for a basic subscription fee, eliminating capital costs, freeing up internal IT resources, and providing online access to version updates. Datastream Systems, Inc.; www.dstm.com
TO VOTE, WRITE 140 ON BALLOT
For more information, circle 140 on card
Tool control system easy-to-use and reduces tracking time
TCS (tool control system) V 8.0 improves ease of use for beginners and cuts tool check out/check in and tracking time as much as 80%. Customization feature lets the user set up individual screen layouts for maximum efficiency and security. Tool crib management software features fully integrated tool kit tracking, tool maintenance, shop labor, inventory, purchasing, bar coding, networking, and more. MicroWest Software Systems, Inc.; www.microwestsoftware.com
TO VOTE, WRITE 156 ON BALLOT
For more information, circle 156 on card
Training system teaches condition monitoring
iLearnInteractive CD-ROM-based training system is designed to teach maintenance staffs about condition monitoring, with a focus on vibration analysis. Five interrelated modules let both inexperienced and experienced technicians learn. Students can pick and choose from the modules, selecting the areas they need most. Mobius Software P/L; www.mobius-online.com
T O VOTE, WRITE 183 ON BALLOT
For more information, circle 183 on card
Maintenance & Safety
