Gas monitors
Ultima XL/XT series gas monitors provide HART field communications protocol with 4-20 mA output. It is designed for use in refineries, chemical and petrochemical facilities and steel mills. A remote display can be viewed through a portable handheld communicator, host DCS or laptop. The units are used to detect combustible and toxic gases, and for oxygen deficiency.
By Plant Engineering Staff December 15, 2007
MSA www.msanorthamerica.com
