Gas analyzer
The Model 9000 RM is a single- or multi-component gas analyzer housed in a single 19-inch, rack-mountable unit that can be integrated into continuous emission monitor systems.
By Plant Engineering Staff April 16, 2008
The Model 9000 RM is a single- or multi-component gas analyzer housed in a single 19-inch, rack-mountable unit that can be integrated into continuous emission monitor systems. The analyzer measures gas species that absorb in the UV. The optional low range white cell provides a longer path length for measuring lower concentrations. The analyzer’s parameters, including graphing, logging and trending, are available by remote and local access. The keyboard and built-in display enable programming of such variables as timing and frequency of local zero and span checks and calibration gas values.
Ametek Process Instruments
www.ametekpi.com
Related Resources
