Flush cutter
The LX-T micro-shear flush cutter features a precision tip that is tapered to reach into tight spaces and produce a clean, square cut on soft wire up to 20 AWG (0.8 mm). Designed with an ergonomic handle, cushioned rubber grips and a light-touch return spring, the rugged cutter has precision-ground, high-carbon-steel blades that are heat treated to Rc 55–57 C.
10/01/2006
The LX-T micro-shear flush cutter features a precision tip that is tapered to reach into tight spaces and produce a clean, square cut on soft wire up to 20 AWG (0.8 mm). Designed with an ergonomic handle, cushioned rubber grips and a light-touch return spring, the rugged cutter has precision-ground, high-carbon-steel blades that are heat treated to Rc 55%%MDASSML%%57 C. Capable of performing millions of cuts, the flush cutter employs the firm’s patented bypass cutting technology, which requires less effort than conventional, compression-type cutters. Static control grips are optional, and models with lead retainers are available.
Xuron Corp.
www.xuron.com
October 2018
September 2018
July/Aug
October 2018
August 2018
October 2018
September 2018
