Flowmeter, temperature transmitters
The ROHS-compliant FV100 Series is made up of in-line flow meters that use the vortex shedding measuring principle. The devices have no moving parts, and LEDs display flow in either liters or gallons. The units can measure flow in either direction and can be used with nonviscous, clean or dirty, water-like liquids.
The ROHS-compliant FV100 Series is made up of in-line flow meters that use the vortex shedding measuring principle. The devices have no moving parts, and LEDs display flow in either liters or gallons. The units can measure flow in either direction and can be used with nonviscous, clean or dirty, water-like liquids. The series is suitable for cooling loops that use water or 50% glycols and for up to 10% water-soluble machine coolant.
Omega Engineering, Inc.
www.omega.com
