Flow controller
The Air and Water PFE Flow Controller allows different air pressure settings to be set for time of day or week for plant operations
January 30, 2014
The Air & Water PFE Flow Controller with Deluxe control panel allows the user to set different air pressure settings for time or day of week. The Air & Water PFE Flow Control Valve will automatically adjust plant air pressure to the lower pressure set point during this non-production time. Operating at the lower pressure set point will greatly reducing compressed air usage resulting in significant compressor KW reduction/energy savings. The Atlas Air & Water PFE Flow Control Valve automatically restores air pressure to the higher pressure set point at desired time/day for plant production.
Atlas Air & Water
www.atlasairandwater.com
