Flexible pneumatic fittings
The NITRA fittings are constructed with thermoplastic bodies and stass steel tube gripping claws.
NITRA line of pneumatics products come with straight, branch, union, Y, reducer, elbow and bulkhead fittings in 1/8 in and 5/16 in tube connection sizes. Designed to work with flexible pneumatic tubing, these fittings are constructed with thermoplastic bodies and stass steel tube gripping claws; additional fittings with nickel-plated brass bodies are available.
Yellow nylon coiled hoses with nickel-plated brass male swivel NPT fittings are available in 1/4-in, 3/8-in and 1/2-in sizes and in 10 to 40-ft lengths. These nylon hoses have a low moisture absorption rate and are fitted with spring guards to resist kinking.
AutomationDirect
www.automationdirect.com
