Fire protection valve series
The FireLock Series 745 Fire-Pac has been updated to give customers more options and benefits for installation, maintenance, and design as well as a lower profile.
Victaulic has made improvements to its FireLock Series 745 Fire-Pac, which is a pre-assembled fire protection valve and trim that is pre-wired to a fire alarm control panel or junction box and enclosed inside a metal cabinet. The improvements give customers more options and benefits for installation, maintenance and design as well as a lower profile. The Fire-Pac can be used in a wider range of operating environments thanks to new insulation and heating components for ambient temperatures as low as 20 F. The FireLock Series 745 is also weatherproofed to an equivalent of NEMA 4 standards to keep out moisture and dirt.
Victaulic
