Filter removes excess oil from airlines
Encapulator high efficiency filtration system is used in applications where there is an excessive amount of oil or other contaminants passing through compressed airlines.
Encapulator high efficiency filtration system is used in applications where there is an excessive amount of oil or other contaminants passing through compressed airlines. This four-stage system protects air-operated equipment by filtering contaminants down to 5 microns.
La-Man Corp.
www.laman.com
