Filling empty air tanks
Problem: Is there a quick and easy way to fill a portable air tank? Solution: Turn off the ball valve and attach the empty air tank hose and compressed air line connectors. Turn on the ball valve until the tank is at line pressure.
Solution: Turn off the ball valve and attach the empty air tank hose and compressed air line connectors. Turn on the ball valve until the tank is at line pressure. Turn off the ball valve and remove the full air tank.
Contributor: Glenn Fisher, Chickamauga, GA
