Feeder control module
This single-feeder control module is a closed-loop rate controller designed to be used with auger, belt and vibratory-based feeders, and mounts directly into an Allen-Bradley ControlLogix chassis.
02/24/2010
Hardy Instruments Feeder Control Module
The HI 1756-FC single-feeder control module mounts directlyinto an Allen-Bradley ControlLogix chassis. The module is a closed-loop ratecontroller designed to be used with auger, belt and vibratory-based feeders,converting them from volumetric to gravimetric feeding. This rate controller featurestrue five-point automatic rate calibration, automatic feeder refill and variousalarms including rate tolerance and disturbance using the PLC's rack I/O.
The feeder control module was developed with Allen-BradleyControlLogix Add-On Profile (AOP). This feature allows the end user to quicklyand easily configure the instrument for their application through PLC softwareon a PC. It is also fully integrated into the Allen-Bradley IntegratedArchitecture Builder (IAB). IAB allows the end user to spec out and designtheir system for optimal productivity, increasing speed and simplifyingintegration with the click of a mouse. In addition, Hardy Instruments providessample ladder logic building blocks of code that can easily be inserted intoexisting code to quickly program the feeder system application.
The HI 1756-FC also includes Hardy's core technologies ofWAVERSAVER to eliminate the effects of surrounding vibration for fast, stableweight display, C2 electronic calibration without test weights and INTEGRATEDTECHNICIAN (IT) for system diagnostics and troubleshooting.
Hardy Instruments
www.hardyinstruments.com
July/Aug
August 2018
August 2018
