Fan coil unit
The Model VSH vertical stack high-rise fan coil unit from Greenheck provides space heating and cooling for hotels, dorms, and condominiums. Available in six sizes with performance capabilities up to 1,300 cfm, the unit is also available with concealed or exposed housings that are configurable with 2-or 4-pipe water coils and electric heaters.
The Model VSH vertical stack high-rise fan coil unit from Greenheck provides space heating and cooling for hotels, dorms, and condominiums. Available in six sizes with performance capabilities up to 1,300 cfm, the unit is also available with concealed or exposed housings that are configurable with 2-or 4-pipe water coils and electric heaters. The unit consists of a three-speed PSC motor, 1-in. fiberglass insulation, 1-in. MERV 5 disposable filter, supply air plenum, and double deflection grille.
