Exit sign retrofit meets UL standards
The 2000 ALS is the only universal exit sign retrofit kit that is UL approved for listing under brightness standards in UL Life Safety Code 924.
The 2000 ALS is the only universal exit sign retrofit kit that is UL approved for listing under brightness standards in UL Life Safety Code 924. Replacing incandescent lamps with the kit results in a significant electric energy savings (about 93%, or $32/ sign/yr based on $0.10/kWh).
AstraLite
www.led.com/astralite
