Exhaust valves
Equipment damage during start-up and shutdown of air-operated equipment can be reduced by the Norgren Excelon P72F-2AC-PFA series designed to block inlet air and exhaust downstream air when a pilot signal is removed
Equipment damage during start-up and shutdown of air-operated equipment can be reduced by the Norgren Excelon P72F-2AC-PFA series designed to block inlet air and exhaust downstream air when a pilot signal is removed. Alternatively, closing an optional manual lockout slide can trigger the same action if installed. All units are CE compliant. Omega Engineering Inc. www.omega.com
