Emergency lighting control devices
Schneider released three emergency lighting control solutions.
June 10, 2012
Schneider Electric has three emergency lighting control solutions: the UL924 Emergency Lighting Control Relay, the UL924 Emergency Lighting Control Relay with Panel Mount, and the UL924 Emergency Lighting Dimmer Control. The UL924 Emergency Lighting Control products offer a versatile, simple, and energy-efficient solution that enables standard, existing fixtures to also be used for emergency lighting applications, saving the costs associated with the installation of additional emergency lighting fixtures. Also, the emergency lighting control devices require less maintenance and fewer testing requirements than backup batteries require because they comply with the UL924 standard, reducing installation time.
Schneider Electric
www.schneider-electric.com/us
