Electric Motors, Drives & Controls
Click on the above link to see Product of the Year finalists in this category.
11/01/2001
Note to our readers: Product of the Year finalists are listed below. To view the products, please
. It
Motor label indicates energy cost savings
Energy guide labels for electric motors highlight energy cost and potential savings from using premium-efficiency motors. The label lists the type and speed of the motor to which it is attached and provides a comparison of the motor's rating to the rating of an average installed motor. It also estimates annual savings of the motor, as well as the cost of electricity to run it continuously. Baldor Electric Co.; www.baldor.com
TO VOTE, WRITE 74 ON BALLOT
For more information, write 74 on card
Washdown motor endures daily cleaning
The ToshWash SS stainless steel washdown-duty motor features a smooth stainless steel shell and the ability to endure daily high-pressure cleaning with hot cleaning agents. It is available from fractional to 5 hp, and features a 3-hp model without an external cooling fan. There is no fan or shroud to trap process residue and no nameplate — product information is etched directly into the frame. Toshiba International Corp., Industrial Products Div.; www.tic.toshiba.com
TO VOTE, WRITE 185 ON BALLOT
For more information, write 185 on card
Motor starters install without tools
TeSys D-Line motor starters and contactors allow for up to 50% reduction in installation time, 80% less wiring, and 30% less space. No tools are required for assembly/connection. Connections are established via direct link to PLCs or networks. The control and power wiring terminations are color coded, reducing the risk of miswired connections. Preformed wire jumpers further enhance user safety. Square D/Schneider Electric, Motor Control Div.; www.SquareD.com
TO VOTE, WRITE 159 ON BALLOT
For more information, write 159 on card
Motor rides through power sags
The Power-Ride 70-hp two-pole motor is a three-phase, Written-Pole motor with a high-inertia rotor. It starts with very low starting current, then runs synchronously at unity power factor with high efficiency. It rides through power interruptions to 15 sec and easily restarts and reaccelerates to full speed. It also features low harmonic input and high starting torque/amp. Precise Power Corp.; www.precisepwr.com
TO VOTE, WRITE 87 ON BALLOT
For more information, write 87 on card
Ac motors replace dc motors
The MicroMAX line of low-horsepower, ac inverter duty motors is designed to replace a permanent magnet dc (PMDC) motor, while requiring virtually no maintenance. Available from stock in1/ 4 -3 hp, the C face motors use the same mounting configurations as their PMDC counterparts. When equipped with a PWM scalar drive, up to a 30% cost savings can be realized. Marathon Electric; www.marathonelectric.com
TO VOTE, WRITE 201 ON BALLOT
For more information, write 201 on card
Motor load monitor measures shaft power
The Digital Load Monitor measures a motor's rotor shaft power. It measures the actual motor load for a 3-sec interval, then automatically sets an alarm level. It has three monitors in one — overload, underload, and an over and underload. The prealarm provides an alarm before the main alarm actuates to prevent unnecessary process interruptions. Emerson Motors; www.emersonmotors.com
TO VOTE, WRITE 101 ON BALLOT
For more information, write 101 on card
March 2018
December 2017
Maintenance & Safety
Industrial Analytics
IIoT: Operations & IT
