EC: SVR-PL Series ultra-wide temperature ac power line regulator
Power – Energy, power protection: The SVR-PL ultra-wide temperature ac power line regulator from Falcon Electric provides clean, regulated, sinewave output power in harsh temperature environments. This is a Control Engineering 2012 Engineers’ Choice honorable mention.
Designed to operate from -22 to +149 F (-30 to 65 C), the UL-listed SVR-PL rackmount and tower configured ac line regulators from Falcon Electric are ideal for use in variable high and low temperature applications where maintaining a constant temperature is required. The SVR-PL Series delivers the highest level of protection against a wide spectrum of power problems compared to the typical power conditioner that relies on a tap-switching transformer to crudely regulate the output voltage.
Due to the unit’s flexible design platform, the SVR-PL can be configured as a frequency converter for worldwide power applications. Accepting a 50/60 Hz input and providing a fixed 60 Hz or 50 Hz output, the SVR-PL supplies a tightly regulated output of ±2% and excellent extended brownout protection. In addition, optional batteries may be installed inside the SVR-PL that were specifically selected due to their ultra-wide operational temperature range of -40 to 176 F (-40 to 80 C), far in excess of the maximum 149 F SVR-PL specification. The batteries have a 10-year service life rating when operated in a normal ambient temperature environment of 72 F. The SVR-PL is equipped with an NFPA-70, NEC 645-11 compliant Remote Emergency Power Off (REPO) interface assuring easy integration. Remote output receptacle control is an option to REPO, allowing the load segment outlets to be remotely controlled using a wire-connected remote switch.
www.falconups.com/SVR_PRO_1_5-3K%20Brochure.pdf
Falcon Electric
Return to the list of the 2012 Engineers’ Choice honorable mentions.
View the list of the 2012 Engineers’ Choice winners.
View the complete list of the 2012 Engineers’ Choice finalists.
