EC: FPM-8151H Stainless Steel industrial monitor
Hardware – HMI, operator interface, thin-client: Advantech's FPM-8151H is a 15-in. 316 stainless steel C1D2 industrial monitor. This is a Control Engineering 2012 Engineers’ Choice award winner.
Advantech’s FPM-8151H is a rugged XGA industrial monitor equipped to handle temperatures ranging from -20 C to 60 C. The stainless steel 316L front panel is NEMA4/IP65 compliant, providing better corrosion prevention ability than regular stainless steel, which makes it more suitable for environment required wash-downs. The monitor meets all the hazardous requirements with UL C1D2 certification. It has a combination RS-232 and USB interface for touchscreen functions, direct VGA and DVI-D video input interface, five-wire resistive touchpanel, and an OSD control pad with lockable function. The FPM-8151H is designed to safely operate in hazardous locations, making it ideal for the oil and gas industry.
www.advantech.com/products/FPM-8151H/mod_033F989A-EF77-40B9-8FE6-3548A1E76290.aspx
Advantech
Return to the list of the 2012 Engineers’ Choice award winners.
View the list of the 2012 Engineers’ Choice honorable mentions.
View the complete list of the 2012 Engineers’ Choice finalists.
