Discrete and analog IO modules
AutomationDirect’s Productivity2000 programmable controller line includes discrete and analog input and output modules.
AutomationDirect’s Productivity2000 programmable controller line includes discrete and analog input and output modules. The ac and dc discrete input/output (I/O) modules include 8-point, 100-120 Vac input and output modules, 8 and 15-point, 3.3-24 Vdc input and output modules and high-density, 32-point, 12-24 Vdc input modules. These I/O modules are designed to allow easy connections for photo eyes, proximity sensors, limit switches, pushbuttons, light curtains, or any other discrete control device. The 12-bit, low-resolution, 4-channel, current and voltage analog I/O modules are designed to precisely measure and control process variables such as level, flow, and pressure. Pre-wired ZIPLinks wiring systems eliminate the need for hand wiring modules to terminal blocks.
AutomationDirect
www.automationdirect.com
– Edited by CFE Media. See more Control Engineering I/O system and module products.
