Disconnect switches
The DS30AX safety disconnect switch is a compact, 30-A, 600-Vac, non-fused switch that meets IP67 and NEMA Type 3R, 4X and 12K standards for watertight and dust-tight enclosures. Designed for motor disconnect applications, the switch has 4 mounting feet and features seven conduit entry points, an integral ground plate and a factory-installed auxiliary contact.
10/15/2008
The DS30AX safety disconnect switch is a compact, 30-A, 600-Vac, non-fused switch that meets IP67 and NEMA Type 3R, 4X and 12K standards for watertight and dust-tight enclosures. Designed for motor disconnect applications, the switch has 4 mounting feet and features seven conduit entry points, an integral ground plate and a factory-installed auxiliary contact. The switch’s front-operated handle and bottom-hinged cover fits into tight spaces and meets OSHA safety regulations.
Leviton Manufacturing Co. Inc.
www.leviton.com
March 2018
Jan/Feb 2018
December 2017
December 2017
Maintenance & Safety
Industrial Analytics
IIoT: Operations & IT
