DIN-rail power supply series for industrial, hazardous applications
Idec's PS5R-V line of DIN-rail power supplies are designed for use in demanding industrial applications and are approved for use in hazardous location applications such as oil and gas processing and petrochemical facilities.
Idec’s PS5R-V line of DIN-rail power supplies are designed for use in demanding industrial applications and improve upon existing models in many areas. The PS5R-V line of power supplies includes 7.5, 10, 15, 30, 60, 90, 120, and 240W versions. Combined with DIN-rail mounting, the reduced form factors free up valuable control panel space and reduce installation costs. It has an operating temperature range from -25 to 75 C, which allows these power supplies to be used in control panels without the need for air conditioning or other cooling devices. They also feature spring-up screw terminals that accept ring and fork terminals, as well as stripped wire for increased flexibility. The PS5R-V line of power supplies is approved for installation in Class I Division 2 environments in standard control cabinets, making them ideal for use in hazardous location applications such as oil and gas processing and petrochemical facilities.
Idec Corporation
– Edited by CFE Media. See more Control Engineering energy and power products.
