Differential pressure transmitter series
Omega's P2600 series of rangeable, differential pressure transmitters can output either static (gage) pressure or differential pressure and are designed for applications like building energy management systems and process control systems.
Omega’s P2600 series of rangeable, differential pressure transmitters can output either static (gage) pressure or differential pressure. The PX2600 series has 4 unidirectional and 4 bi-directional ranges, 3 selectable outputs (0 to 5 Vdc, 0 to 10 Vdc, 4 to 20 mA 2-wire), pushbutton or remote zero, 4-digit LCD with the ability to show either static or differential pressure and this CE-compliant product comes with a durable glass filled polyester case. The transmitters are designed for applications like building energy management systems, process control systems, and pressure drops across ductwork.
Omega Engineering
Omega Engineering | Sensing, Monitoring and Control Solutions
– Edited by CFE Media. See more Control Engineering process sensor and actuator products.
