Conveyor reducer has flange mounting
CFA700 Series direct mount, conveyor speed reducer has an output flange mounting style and eliminates loose parts normally required for installation. This compact unit eliminates mounting hardware and chain maintenance. The unit reduces maintenance costs by eliminating chain stretch and sprocket changeovers.
CFA700 Series direct mount, conveyor speed reducer has an output flange mounting style and eliminates loose parts normally required for installation. This compact unit eliminates mounting hardware and chain maintenance. The unit reduces maintenance costs by eliminating chain stretch and sprocket changeovers. Units are equipped with PosiVent and factory-filled lubricant, which eliminates oil changes. Boston Gear : www.bostongear.com
TO VOTE, WRITE 22 ON BALLOT
For more information, write 22 on card
