Conveyor easily adjusts to match load
E-Z conveyor system is a versatile, low-noise solution for vibratory handling with build-your-own capabilities.
E-Z conveyor system is a versatile, low-noise solution for vibratory handling with build-your-own capabilities. Versatility is a result of a vibrator mount and control to instantly find and maintain the resonant frequency of leaf springs, even when the load or air pressure changes. To change the conveying rate, merely change air pressure or throttle the exhaust.
Martin Engineering
