Control transformers
HPS Imperator series transformers are designed for inrush applications that require output voltage stability. The series is designed to maximize inrush capability and output voltage regulation when electromagnetic devices are energized, and its fin-shaped design is made of steel laminations. The transformers are 50/60 Hz, 600-V class, machine-tool rated with ratings from 50 VA up to 1,000 VA.
11/15/2007
HPS Imperator series transformers are designed for inrush applications that require output voltage stability. The series is designed to maximize inrush capability and output voltage regulation when electromagnetic devices are energized, and its fin-shaped design is made of steel laminations. The transformers are 50/60 Hz, 600-V class, machine-tool rated with ratings from 50 VA up to 1,000 VA. The series is UL listed, CE marked and RoHS compliant.
AutomationDirect www.automationdirect.com
Maintenance & Safety
