Contact-cooled compressors
Designed for use in automotive, metal fabrication, conveyance, textile manufacturing and other applications, contact-cooled compressors feature a proprietary Intelligent Controller.
By Plant Engineering Staff December 12, 2008
Designed for use in automotive, metal fabrication, conveyance, textile manufacturing and other applications, contact-cooled compressors feature a proprietary Intelligent Controller. Equipped with intuitive operator control that includes an LCD graphic interface, the controller includes selectable software with adjustable operating parameters, a built -in sequencer that can coordinate up to three machines, and time-saving diagnostics with displays that identify and alert operators of system overload with machine shut-down when required. The units’ Rapid Stop power conservation system eliminates unloaded running time and protects motors.
Ingersoll Rand
www.ingersollrand.com
