Construction, Buildings and Grounds
11/01/2003
Door guard prevents untimely passage
Roll-Up Door Guard is a unique collision prevention system that provides a physical barrier to prevent a vehicle operator from driving through an overhead door before it is fully opened. Easily installed on both manual and automatic overhead doors, it remains down until the door is safely out of the way, then opens to allow traffic. Guard is mechanically linked to door, so no power is required. Increased safety and elimination of damage are benefits.
Discovery Mfg. : discoverymanufacturing.com , TO VOTE, WRITE 2 ON BALLOT For more information, write 2 on card
Strip door kit installs in 5 min
Curtronizer strip door kit contains everything needed for 5-min installation, including drill bit and screws. Worn strips can be replaced in minutes without tools. Designed for food service environments, the polypropylene hardware forms an enclosed mounting bar that won't catch dirt and grease. Design accommodates 6 and 8-in.-wide PVC strips with overlaps from 25% to 100%. Choice of two material grades handles temperatures from -40 to 160 F.
TMI Inc.; Curtron Products Div. : curtronproducts.com , TO VOTE, WRITE 94 ON BALLOT For more information, write 94 on card
Screen panel ventilates dock area
GX-4000 Ventilation Screen panel retrofits into dock doors to allow air flow into the dock area and plant while preventing bugs from entering. The 12-in.-high panel is easily installed into most doors up to 14-ft 2-in. wide. In addition to the stainless steel screen, the panel includes a hinged ABS cover for security and shielding against inclement weather. A translucent cover is optional. Screens are available in 0.83 by 0.83-in. or 0.30 by 0.30-in. hole sizes.
Rite-Hite Aftermarket Corp. : ritehite.com , TO VOTE, WRITE 38 ON BALLOT For more information, write 38 on card
Wall repair patch saves time, money
Wet & Set drywall and ceiling repair patches have the first coat of compound already on the patch. Patch is simply cut to size, dipped in warm water, and placed over the damaged area. After 15 to 30 min of drying, spackle or compound can be applied for finishing. Patches can be used on drywall, plaster, painted wood, and stucco. Surfaces can be flat, uneven, or curved. Material comes in 5-in. by 15-in. patches and 5-in. by 9-ft rolls.
Hyde Tools : hydetools.com , TO VOTE, WRITE 73 ON BALLOT For more information, write 73 on card
Door controller is programmable
System 3 variable-speed ac-drive controller combines the flexibility and performance of ac drive technology with the ease and precision of digital control. Numerous preset and customizable programming capabilities accommodate a variety of door and traffic systems without additional electrical components. Optical position sensor eliminates mechanical limit switches. Variable-frequency drive provides soft starts and stops. Dynamic braking eliminates adjustments and reduces brake wear.
Rytec Corp. : rytecdoors.com , TO VOTE, WRITE 47 ON BALLOT For more information, write 47 on card
Fasteners speed structure assembly
MQN pushbutton structural fasteners offer a one-piece design that replaces the spring nut, bolt, and washer combination traditionally used to attach strut angles, clamps, connectors, and baseplates. A quick press, turn, and tightening are all that's needed to attach a variety of connectors to C-profile steel struts. Large inventories of bolts, nuts, and washers are reduced. Connections can be easily adjusted, removed, and reused.
Hilti Inc.; Installation Systems : us.hilti.com , TO VOTE, WRITE 110 ON BALLOT For more information, write 110 on card
Strip door system makes replacements easy
Save-T Loc provides a versatile system for creating and maintaining strip doors. Available in galvanized steel, stainless steel, or aluminum, the hardware can be header or wall mounted. Once installed, no tools are required for strip replacement. System accepts strips 0.04 to 0.36 in. thick with holes from 5/16 to 3/4 in. in diameter. Multiset studs and retainer bars prohibit strips from coming loose in two-way traffic.
TMI Inc. : tmi-pvc.com , TO VOTE, WRITE 91 ON BALLOT For more information, write 91 on card
Safety zone extends beyond doorway
I-Zone area detection system uses infrared sensing to create a 7-ft-deep safety zone that prevents or stops a closing door before a pedestrian enters the doorway. Intersecting infrared beams detect people as they approach the door from either side. An open door stays open; a closing door reverses travel. A self-monitoring feature sounds an alarm if a potential problem with the system is detected. System can be added to existing door installations.
Rite-Hite Doors, Inc. : ritehite.com , TO VOTE, WRITE 175 ON BALLOT For more information, write 175 on card
Door withstands impacts from either direction
IXP Impactor fiberglass biparting cooler/freezer door has center breakaway panels to withstand collisions with vehicles from both sides. After an impact, the door returns to its normal operating position without the need for repairs or adjustments. Operating speeds are 8 ft/sec opening and 4 ft/sec closing. Panels are fully insulated reinforced fiberglass. Stainless steel and nylon mechanisms prevent rust and corrosion. Overhead suspension system eliminates any floor hardware.
ASI Technologies, Inc. : asidoors.com , TO VOTE, WRITE 49 ON BALLOT For more information, write 49 on card
March 2018
Maintenance & Safety
Industrial Analytics
IIoT: Operations & IT
