Connectors: All-plastic industrial design accepts larger cable
Binder-USA released a new version of the 692 and 693 series connectors. Cable plugs now will accept multi-conductor cables having an outer diameter of up to 14 mm. Previously, the largest acceptable cable diameter was 12 mm.
Binder-USA
Binder-USA released a new version of the 692 and 693 series connectors good for outer cable diameters of 14 mm. |
The new designs maintain the IP67 environmental protection rating when fully mated and terminated to cable having an outer diameter within the recommended range, which varies by part number, company says. The connectors are available with or without SEV, VDE, and UL approvals. Male and female cable plugs or panel-mount, flanged sockets are available with two contact configurations: 3+PE and 6+PE. The available termination styles include screw-type, solder-cup and crimp terminations (crimp contacts & crimp tooling ordered separately). The 692 and 693 series connectors are intermateable and interchangeable with other manufacturers’ industry standard connectors.
— Control Engineering System Integration eNewsletter
( Register here and scroll down to select your choice of eNewsletters free .)
