Condensate pump designed for long life cycles
Pivotrol pressure powered condensate pump is engineered for dependable steam system condensate recovery in rapid-cycling process environments and under all pressure and temperature conditions. The pump mechanism replaces pins and linkages with pivots, which reduce friction and wear, lengthening service life.
11/01/2005
Pivotrol pressure powered condensate pump is engineered for dependable steam system condensate recovery in rapid-cycling process environments and under all pressure and temperature conditions. The pump mechanism replaces pins and linkages with pivots, which reduce friction and wear, lengthening service life. A special damper uses hydraulic inertia of the collected condensate to reduce mechanical shock as valve actuators shift. Spirax Sarco, Inc. : www.spiraxsarco.com/us
TO VOTE, WRITE 06 ON BALLOT
For more information, write 06 on card
Maintenance & Safety
