Compressor delivers air and nitrogen
GN range of dual output air compressors generate nitrogen and compressed air simultaneously. 4 kW, 7 kW and 18 kW units are available with several levels of nitrogen output for each unit. Nitrogen flow starts at 0.6 cfm and goes up to 18 cfm with a purity of 95%. The dual output compressor system uses a screw compressor, tank mounted, an integrated refrigerant dryer and filters and a membrane t...
11/01/2005
GN range of dual output air compressors generate nitrogen and compressed air simultaneously. 4 kW, 7 kW and 18 kW units are available with several levels of nitrogen output for each unit. Nitrogen flow starts at 0.6 cfm and goes up to 18 cfm with a purity of 95%. The dual output compressor system uses a screw compressor, tank mounted, an integrated refrigerant dryer and filters and a membrane that passes nitrogen. Atlas Copco Compressors Inc. : www.atlascopco.us
TO VOTE, WRITE 156 ON BALLOT
For more information, write 156 on card
August 2018
August 2018
