Compression connector
The Space Saver EMT compression connector is UL-listed, raintight and used to join EMT conduit to a box or enclosure. The connector's design puts male threads on the locknut, reducing the space the fitting requires inside the box or enclosure. Its smooth pulling surface can eliminate the need for throat fittings or conduit bushings.
11/15/2007
The Space Saver EMT compression connector is UL-listed, raintight and used to join EMT conduit to a box or enclosure. The connector's design puts male threads on the locknut, reducing the space the fitting requires inside the box or enclosure. Its smooth pulling surface can eliminate the need for throat fittings or conduit bushings. Their hex-shaped gland nut facilitates wrenching and does not need to be disassembled to install conduit. A rubber gasket provides a positive seal to ensure raintight service.
Cooper Crouse-Hinds, Commercial Products div. : www.crouse-hinds.com
Maintenance & Safety
