Compressed Air – 2001-11-01
Click on the above link to see Product of the Year finalists in this category.
By Staff November 1, 2001
Note to our readers: Product of the Year finalists are listed below. To view the products, please download
. It
Compressor has direct drive
DSD and ESD one-to-one, direct drive, rotary screw compressors eliminate drive losses by using a maintenance-free, flexible, drop-out coupling to directly connect the motor to the airend. Three distinct airflow zones combined with a radial cooling fan reduce noise levels to as low as 70 dBA. Sigma Control ensures the compressor operates at optimum efficiency throughout its 100-300 hp range. Kaeser Compressors, Inc.; www.kaesercompressors.com
TO VOTE, WRITE 178 ON BALLOT
For more information, write 178 on card
Compressor control saves energy
Smart Sequencer reduces a plant’s energy costs by continuously monitoring compressed air requirements and automatically selecting the most energy-efficient compressor combination to meet the load. Maintenance and repair costs are also reduced by running only the necessary compressors. Displays include compressor status, pressure and flow rates, alarms, and alarm history. Scales Air Compressor Corp.; www.scalesaircompressor.com
TO VOTE, WRITE 57 ON BALLOT
For more information, write 57 on card
Air coupler vents before disconnect
C9000 is an innovative safety coupler for pneumatic applications. The unique two-turn release quickly vents downstream air pressure before disconnecting, preventing injuries associated with hose whip. The unit is made from a tough composite material that stands up to abuse. Sealing characteristics are maintained even after 2 million cycles. Legris-Transair; www.legris.com
TO VOTE, WRITE 62 ON BALLOT
For more information, write 62 on card
Mini air dryer has quick-change filter
Pneudri Midas is a mini dry air system that provides uninterrupted clean, dry compressed air just where needed. The unit contains a high-efficiency particulate filter and desiccant cartridge in a single module. Unit can be serviced 100% in less than 15 min. due to a quick release top cap, which does not require the ports to be disconnected. Flow range is 3-20 cfm at 100 psig. domnick hunter ltd.; www.domnickhunter.com
TO VOTE, WRITE 88 ON BALLOT
For more information, write 88 on card
Variable speed drives compressor
Variable speed drives (VSD) have been added to Kobelco KNW Series oil-free, two-stage, rotary screw air compressors. These variable speed/variable capacity units are available in 00, 0, 1, and 2 frame sizes, air and water-cooled versions. The VSD units allow users to precisely match compressor output to variable compressed air demands. Rogers Machinery Co., Inc.; www.knw-series.com
TO VOTE, WRITE 76 ON BALLOT
For more information, write 76 on card
Compressor is easy to service
TS-32 Series air compressors have a Supervisor Controller with four-line, full-text display, built-in lid lifter which allows the separator to be easily changed, fiberglass fluid filter with coreless element to improve filtration, and large cleanout ports on integral, air-cooled oil and aftercoolers that provide easy maintenance. The two-stage airend extends bearing life. Sullair Corp.; www.sullair.com
TO VOTE, WRITE 139 ON BALLOT
For more information, write 139 on card
Air dryer prevents flood back
Elite Series refrigerated air dryers protect the compressor from refrigerant flood back, improve performance by doubling the effective area of the main evaporator, and eliminate the need for precision adjustments on the thermostatic expansion valve. The Cold Point coalescing configuration uses a dual-stage coalescing filter in place of a centrifugal moisture separator. Airtek; www.airtek.com
TO VOTE, WRITE 209 ON BALLOT
For more information, write 209 on card
Centrifugal compressor uses no water
Turbo Air Cooled 2000 centrifugal compressor is designed for applications where there is a limited supply or no water available for cooling. Air-to-air heat exchangers provide performance comparable to water-cooled compressors. Users save money on the cost of water as well as the cost of pumping, treating, and maintaining a water system. Cooper Turbocompressor; www.turbocompressor.com
TO VOTE, WRITE 146 ON BALLOT
For more information, write 146 on card
Air dryer saves space
G Series refrigerated compressed air dryers have been engineered to be compact and lightweight, providing broad installation flexibility and economy. Footprint is 2.25 or 3.5 sq ft depending on model. Available in 75, 100, 125, and 150-scfm capacities, these models are designed for easy installation and servicability in small and difficult-to-reach spaces, typical in many compressed air system installations. Zeks Compressed Air Solutions; www.zeks.com
TO VOTE, WRITE 221 ON BALLOT
For more information, write 221 on card
Compressor matches air demand
ZR160 VSD two-stage, water-cooled, oil-free, rotary screw air compressor with variable speed drive motor matches air demand by regulating compressor speed. The drive control has a low starting current, smooth torque curve, and lower average rpm to extend the life of rotating parts. Matched MD400 desiccant dryer motor runs at compressor speeds to match performance and save energy. Atlas Copco Compressors, Inc., Oil-free Air Div.; www.atlascopco.compressors-usa.com
TO VOTE, WRITE 145 ON BALLOT
For more information, write 145 on card
Air dryer drive matches demand
SpeedTrak variable speed, refrigerated air dryers use variable speed technology with microprocessor-based controls to reduce the refrigerant compressor’s power consumption at reduced loads. Dual action air/air and air/refrigerant heat exchangers combine compressed air cooling and moisture separation processes to provide lower pressure drops. Drain valve expels condensate without air loss. Air/Tak, Inc.; www.airtak.com
TO VOTE, WRITE 212 ON BALLOT
For more information, write 212 on card
Compressor drive cuts energy costs
L22-L75 lubricated rotary screw air compressors incorporate a variable speed Switched Reluctance (SR) drive system to precisely match power consumption to demand. This creates potential energy savings up to 50%, while the accurate pressure control and smooth acceleration and deceleration of rotary components extends the service life, improving payback on investment. CompAir; www.CompAir.com
TO VOTE, WRITE 193 ON BALLOT
For more information, write 193 on card
Compressor drive has large turndown
Nirvana variable speed drive rotary screw air compressors optimize the speed of the airend to match the pressure setting with 75% or greater turndown. Maximum flow is achieved in 1 psig increments from 65 to 145 psig. The Hybrid Permanent Magnet motor has unlimited start/stops and is field serviceable with removable stator coils. Increased air gap allows operation up to 115 F. Air Solutions Group, Ingersoll-Rand Corp.; www.air.irco.com/nirvana
TO VOTE, WRITE 166 ON BALLOT
For more information, write 166 on card
Compressor unloaded mode
GA VSD variable speed drive rotary screw air compressors reduce energy consumption to a minimum by completely eliminating unloaded power consumption, saving up to 22% on the total life cycle cost. The completely self-contained package includes in-line air filters, oil-water condensate separator, refrigerated air dryer, automatic drains, and extremely low sound levels. Atlas Copco Compressors, Inc., Industrial Air Div.; www.atlascopco.compressors-usa.com
TO VOTE, WRITE 229 ON BALLOT
For more information, write 229 on card
Air dryer has large capacity
HPRplus Series refrigerated compressed air dryer capacity has been increased to 3000 scfm. The dryer acts as a complete air treatment station, delivering dry, oil-free compressed air while minimizing energy and installation costs. An integral filter/separator removes bulk liquid and particles to 3 microns. An optional coalescing filter removes oil aerosols to 0.008 ppm. Hankison International; https://www.hankisonintl.com/
TO VOTE, WRITE 48 ON BALLOT
For more information, write 48 on card
