Coating thickness tester
The CG206 coating thickness tester is designed to accelerate condition monitoring inspections of industrial storage equipment.
06/09/2017
The CG206 coating thickness tester is designed to accelerate condition monitoring inspections of industrial storage equipment. Courtesy: ExtechThe CG206 coating thickness tester is designed to accelerate condition monitoring inspections of industrial storage equipment, tanks, and vessels in manufacturing and petrochemical sites. It can be used to inspect plant equipment that is prone to damage, corrosion, or deterioration, including chemical or oil storage tanks, boilers, and pressure vessels. In addition to examining newly-installed equipment for quality control, plant maintenance technicians can use the CG206 for periodic condition monitoring to identify changes that indicate a potential structural weakness or failure. It features a measurement range of 0 to 1350μm (0 to 53mils) and automatically powers down after three minutes of inactivity. When constant-on functioning is required, users easily can disable the automatic power-off mode.
Extech
http://www.extech.com/cg206
September 2018
July/Aug
August 2018
August 2018
September 2018
