Circuit breakers – 2009-06-01
Rated up to 125 amp, the NDM1-125 high-current DIN rail-mounted circuit breakers from Automation Systems Interconnect are UL1077 Recognized for use as supplemental protectors. Available in 1-, 2-, and 3-pole versions, the circuit breakers can be ordered in C- or D-trip curves. The circuit breakers are 300% factory tested and feature a 10 kA interrupt capacity and a visual trip indicator.
Automation Systems Interconnect Circle 458
Automation Systems Interconnect Inc. is a CSIA membe as of 2/26/2015
