Chiller saves energy
Horizon absorption water chiller is available in 500-800-ton capacities. The single-stage chiller produces water in the range of 40-60 F using a low-grade heat source of 12-psig steam or 270-F hot water.
By Staff March 1, 2000
Horizon absorption water chiller is available in 500-800-ton capacities. The single-stage chiller produces water in the range of 40-60 F using a low-grade heat source of 12-psig steam or 270-F hot water. The ability to make chilled water from low-temperature inputs is important in energy conserving applications, such as waste heat recovery, cogeneration equipment, and solar-energy powered cooling.
Trane
www.trane.com
Circle 371
