Chemical anchor
The HIT HY 150 MAX Chemical Anchor provides maximum performance in a wide range of base materials and applications. It offers up to 20% higher load capacities than previous models and may be used in oversized holes up to /-inch larger than the rod diameter. It also features a mixer helix and connector, which reduce dispensing forces and optimize mixing quality, to make dispensing easier, help s...
12/01/2005
The HIT HY 150 MAX Chemical Anchor provides maximum performance in a wide range of base materials and applications. It offers up to 20% higher load capacities than previous models and may be used in oversized holes up to /-inch larger than the rod diameter. It also features a mixer helix and connector, which reduce dispensing forces and optimize mixing quality, to make dispensing easier, help save time and reduce waste. This virtually odorless adhesive is used for solid base materials such as concrete, grout-filled block and stone, as well as hollow block and brick and has a temperature range of between 14 to 104 degrees Fahrenheit.
Hilti Inc. www.us.hilti.com Write 311 on PE card
Maintenance & Safety
