CANopen extension module
This module provides CANopen connectivity to Siemens automation and control systems, and Profibus and Profinet protocols.
The 1SI CANopen plug-in extension module brings CANopenconnectivity to the SIMATIC ET200S distributed I/O system, allowing seamlessintegration of CANopen devices into the Siemens automation architecture. TheCANopen module fits mechanically into the standard ET200 system rack and can beused in combination with all other Siemens modules in the ET200S family.
The module enables the easy integration of CANopen enableddevices within the Siemens Profibus and Profinet based automation architecture.Typical applications include machines and automation systems where CANopenenabled drives and Siemens PLCs are used. The CANopen Master configuration ismade via an external CANopen configuration tool.
HMS IndustrialNetworks Inc.
