Back blow air nozzle
The 1/4 NPT back blow air nozzle has been designed to effectively blow debris and liquids from pipe or hose inside diameters, channel, bores, holes, internal threads and other internal part features.
06/11/2015
The 1/4 NPT back blow air nozzle has been designed to effectively blow debris and liquids from pipe or hose inside diameters, channel, bores, holes, internal threads and other internal part features. An array of holes provide a 360-deg airflow to clear out coolant, chips and light oils from machining processes. This nozzle prevents blowing chips further into a part, tube or pipe and eliminates any safety hazard created by blowing debris out the far end of a pipe or tube. The Model 1006SS will fit inside openings as small as 7/8-in. and diameters up to 4-in. It is constructed of type 316 stainless steel to provide durability and resistance to corrosion. Personal protective equipment is recommended since airflow is directed toward the operator.
Exair Corporation
www.exair.com
March 2018
December 2017
Maintenance & Safety
Industrial Analytics
IIoT: Operations & IT
