Automation panel with single-touch operation
B&R Automation's second generation Automation Panel displays feature 4:3 format with single-touch operation and can be combined with a module to create a panel PC.
B&R Automation’s second generation Automation Panel displays feature 4:3 format with single-touch operation and are compatible with existing systems. The panels are part of B&R’s modular system platform, which allows them to be combined with a module to create a panel PC. The Automation Panels can also be equipped with a Smart Display Link 3 receiver that allows the display to be installed at distances up to 100 m from the Automation PC. SDL3 then transmits all necessary data over an ordinary Ethernet cable, with RJ45 connectors that are well-suited for routing through tight openings. Existing visualization applications can be displayed using the latest screen technology on Automation Panels in 4:3 format without having to modify the software a single bit. 12.1 and 15-in. panels with XGA resolution are available for control cabinet installations in addition to a 19-in. panel with SXGA resolution that rounds off the product line. The LED backlight also features an adjustment range that allows the displays to be dimmed for user comfort in environments with lower light levels.
B&R Automation
Industrial automation | B&R Industrial Automation
– Edited by CFE Media. See more Control Engineering HMI and operator interface products.
